Toyota 86 Motec m150 package
1914 Vistas
Just chasing clarification on something in the m150. I want to understand what "Fuel injector secondary contribution main" Means. Just confirming that this number is a percentage of how much the ecu will use the "secondary" or "port" injectors compared to the DI injectors. So if I put 100 in it will mean port injectors fire all the fuel. Reason I ask is because ive been having hot start issues and the numbers in the graph is set to 0 all the way up to 4000rpm.
Thanks in advance everyone :D
Yes you are correct. When Fuel Injector Secondary Contribution Main is selected, pressing F1 will show the help for this table.
