Ethanol & Flex Fuel Tuning
Ajuste de etanol y combustible flexible
Discusión y preguntas relacionadas con el curso Ajuste de etanol y combustible flexible
1623 Vistas
target lambda in WOT (Full Throttle ) in E90 114 OCT for N/A is?
0.885 is fine na full load with good fuel system and ample cooling a little richer if you want a little more safety
