Pumpgas to E85 - injection and ignition
Ajuste de etanol y combustible flexible
Discusión y preguntas relacionadas con el curso Ajuste de etanol y combustible flexible
2299 Vistas
Hi there,
I have a question regarding switching from pumpgas (102 octane) to E85.
The question is related to make a kind of basemap.
For injection, I know to add 30% to 35% of fuel.
But how much can I safe add ignition so that I have a start point for mapping?
I know that finally it must be done on the dyno, but is there a value which I can add to that table? (e.g. 4 degrees or 20%)
As E85 is by far not so knock limited like pumpgas, there should be not so high risk.
Thanx alot :-)
Best regards
Cyril
The percentage of increase in injector flow required for lambda to be the same, is relative to the ethanol content percentage.
30% more flow might be around 50% ethanol / pump gas blend, where 85% ethanol content might be closer to 50% more flow.
generally if your timing is torquey but not misfiring on pump gas, then it will be fine for ethanol blends.
on some engines with high ethanol content fuel, you can increase timing beyond MBT, and to the point of lifting the heads ; good-bye head gasket.
if you know you're near MBT on pump gas, you'll be well-off for starting with ethanol blends.
Hi Jonathan Dilley,
Are you saying that with no Flex Fuel Sensor fitted to an FA20 engine that is forged internal built Stage 1 open deck tuned on a base map with Ecutek, not experiencing any kind of knock/detonation on P98 on safe base turbo map pushing 10 psi. I can change FF content override values to 85 and convert to E85 Ethenol with safe reflash practices?
Have any question prior to giving a final resolution answer? shoot :)
Please confirm and I look forward to your reply, good day :)
