DELETE AIR IDLE CONTROL VALVE
Fundamentos del ajuste de EFI
195 Vistas
Hey tuners. I am continuing the build and install of a new 427 stroker in my road course prepped Fox Body. I've run into an issue in that we planned to use Holley's EFI Universal 1000 CFM throttle body. Well, I can deal with the GM Style Air Intake Temp and TPS, but the simple MSPNP2 that I have does not afford my control of the stepper motors for the GM style AIC. My engine builder is suggesting we simply delete it. I can see where I can disable it in TunerStudio; however what steps / adjustments should I look at to compensate for the lack of the valve?
THANKS in advance for the assistance.
