Good day, I have completed the WinOLS Mastery: Map Identification & Editing course and identified all the maps in this course with my own Audi MED9.1 8P0 907 115AQ ECU along with the Damos file I have for it.
I'm wanting to start by doing a stage 3 remap my current set up is;
1.) Layeo pod air filter and induction pipe.
2.) insert in turbine intake for smooth airflow from induction pipe
3.) APR coil packs
4.) NGK race plugs
5.) 3" down pipe with 100 cell CAT
6.) TTE420 turbo with an APR actuator
7.) I.E intercooler
8.) APR lpfp
9.) Autotech hpfp
10.) 165 Bar fuel rail valve
11.) Runner Flap delete
12.) Stage 4 TVS clutch in a 6 speed DSG 12.) EVC throttle controller
I have a set of RS3 injectors that id like to install at a later date as well so would like to know how to scale the injectors on this ECU?
The maps that I have identified in Winols is;
Desired Relative Air charge KFMIRL (1)
Driver relative request torque From Accelerator: KFPED (6)
Driver requested lambda: LAMFA (3)
Ignition timing: KFZW (6)
Lambda for Component protection (6)
Maximum relative engine load limiters (6)
Optimum EngineTorque output (1)
Optimum EngineTorque output KFMIIOP (1)
Optimum EngineTorque output for Component protection KFMIIOP (2)
What other maps do I need to edit for a build like this?
Thanks for any advice or direction on what course to take next to know how to tune this ECU
