1998 Camaro 6.0l swapped iac and idle issues at start up engine cold only
2249 Vistas
98 Camaro been tuned for ls1 with cam now has 6.0 with big cam been working on tune but ant get to idle cold once you drive it and temp raises any idles fine.
Please help has big lift cam
intake total lift is 0.631 inch,
exhaust total lift is 0.615
duration of intake valve is 285 [email protected],
exhaust DURATION is 300 [email protected],
LSA 112.5,
EVO @0.050 57 DEGREES BBDC,
[email protected] 7 DEGREES ATDC,
[email protected] 5.5 DEGREES BTDC, IVC @0.050 45.5 DEGREES ABDC
INTAKE C/L 110 DEGREES, EXHAUST C/L 115 DEGREES
