Additional Combustion concepts explanation
2005 Vistas
Hi, I came across with some concepts I am not sure if they are handled here in the academy. Do you guys know if they are? See attached.
Not sure if they're addressed directly, as part of the theory, but I do recall cylinder pressure cycles being part of some tutorials. If you don't find what you need, I expect there are some other good on-line tutorials if you need them. It's something we went into at high-school, but that was a long time ago, and sometime later at college - but, again, quite some time ago.
It's indirectly addressed with the discussions about setting the timing for best torque/power which, provided the engine doesn't have detonation/pre-ignition issues first, is basically BMEP for the engine.
