AEM net
1901 Vistas
Anyone one know to look up AEMnet ? I have 2005 Hyundai TIburon v6 5 Speed im using AEM infinity 506 with Boomslang wiring harness. Boomslang was label AEMnet i connected AEM GPS gauge and AEM wideband Fail safe gauge.
Your question is not very clear, but AEMnet is just AEM's terminology for the CAN bus that their devices use to communicate with each other. It is all pretty standard issue CAN bus - 500K bitrate, 29bit extended ID's, with a single 8 byte frame per message.
I aplogize for the not being more specific. I just want to know where to set up my GPS and wideband gauges on Infinity 506 ecu. I try to find AEM net in the Wizard and input taps can not find AEM net.
