All sensors have error
1773 Vistas
Hi,
Last Wednesday I was at the dyno, and to summarize, the driveshaft broke and damaged the oxygen sensor wires. I took the car to the shop; when I tried to start the engine, I couldn't. After the driveshaft failure, all the sensors are now reporting errors. I'll attach photos of the errors to see if you can help me determine what the error might be.
The ECU is Motec gold box hundred series M800.
Any chance you have shorted the sensor ground to the lambda signal, or other low-voltage value? I would start with making sure none of the O2 wiring is shorting together.
If possible, the sensor connector came loose, exposing the wire pins.
Could that short circuit have damaged the ECU?
It's possible I have damaged motec products (ADL dashes) by shorting the 0V pins to 12V. Both times the ADL's were able to be repaired by MoTeC USA.
It was actually my biggest fear.
Thanks for the feedback, even though it was the answer I didn't want to read.
Mr. David can you help me any phone number or link for Motec service?
I admit to not knowing if Panama is considered North or South America. For North America (USA), Contact MoTeC USA :
MoTeC USA
235 Raceway DriveMooresville NC 28117America
Phone: +1 704 799 3800
Fax: +1 704 799 3874
www.motec.com
For South America
MoTeC Latino America
Gaston Scazzuso
Ruta 202 y Av.del golf - depto 805 (Hindu Club)Don Torcuato B1611ELNBuenos Aires, ArgentinaWhatsApp: +54 911 5385 1996
Phone: +54 911 5385 1996
[email protected]
www.moteclatinoamerica.com
You can find all the dealers here: https://www.motec.com.au/dealers
