base map
2264 Vistas
I want to know if I purchase a standalone ECU and want to tune it on my own on road, how will I get the base map for my particular engine? how do I set up the ECU for the base map and then begin turning from there!
Hello, it depends on the type of ECU you buy and the car it is running on,
an example is a link ECU if it is a plug-in link ECU it will come with a base map and a very good help file, great technical help and also a very good forum
