Base Map
2258 Vistas
i hope you are doing well, i want base map for BMW engine - M50B25 - 6 cylinders -
without venous , turbo charged , ECU link extreme, E-throttle or similar for this engine ( Name )
because i know there too much base maps included G4+ and G4X but not similar for my engine ,
i need it to start up the engine just after that i will complete the tuning
hello ;
still no answer until now ?
The E36 plug-in sample map in PC Link is for a M50TU, the only change you will need to make is turn off the vanos output, change the cam sensor type to reluctor and change sync mode to cam pulse 1X. From memory the trigger offset is different, which you can find with a timing light.
