choosing afr
Módulo correspondiente: Principios fundamentales del motor > Relación aire-combustible > Cómo elegir el AFR correcto
732 Vistas
what is the most effective software to get the perfect accurate actual lambda ?
Your question is not clear.
Are you looking for a wideband lambda controller / sensor to measure the actual lambda, and software to log this value?
Tell us more ...
What vehicle and ECU are you using?
Is this for full time installation on a vehicle, or temporary use on a chassis dynamometer or when road testing?
