Correct afr
2134 Vistas
how gasoline quality influences afr
Regardless of the quality or octane of pump gas, the stoichiometric AFR doesn't change. You may find however that low octane fuel may benefit from a richer AFR target at WOT to help make the engine less likely to knock.
