Discrepancy between subtitles and video
Módulo correspondiente: Inyectores de combustible > Flujo del inyector
1710 Vistas
02:44 In the majority of OE ECUs, airflow is either measured directly or calculated in units of mass airflow, and then the required injector pulse width to achieve a target air-fuel ratio is calculated from the mass airflow and the mass flow rate of the injector.
In the video, he says "...pulse width to achieve a target airflow is calculated..."
