Dorito juice
Módulo correspondiente: Principios fundamentales del motor > Relación aire-combustible > Consumo específico de combustible de los frenos
2478 Vistas
What would the range of BSFC be on a turbo rotary?
13 and 20b if possible
Thanks
Can't directly comment, as I've only a passing knowledge of them, but don't expect it to be very good because of the inefficiencies of the engine design, even if correctly tuned. You may be looking at 0.5 lbs/hp/hr, or higher.
I wouldn't worry too much about it, unless you're looking at what injectors to get, pump flow rates, etc. and need a rough size estimate?
