Fundamental Engine Principles
3383 Vistas
hi
what do you mean in (2 revolutions) for clarification
thanks
hi Tanmanreda i havent seen the corse but it would normaly mean that the crank has done 2 turns or 720 degrees / hope that helps dwayne new zealand
Dwayne is right, for every 2 revolutions of the crank shaft the cam shafts and, therefore, engine have only performed 1 revolution
