How are flame maps made?
2281 Vistas
Does any one know what changes need to be made in the spark timing table to make a flame map using the uprev platform?
WHAT IS A "FLAME MAP"?
I believe it's about throwing flames out of exhaust pipe. It just never stops...
Any damage incurred to your engine is your problem.
The basis of it is, retard the timing and add fuel. You want the spark event occurring as the exhaust valves open, igniting the residual unburnt extra fuel we added. This will cause the fuel and air mixture to ignite with the exhaust valves opening/open.
Pop, bang, flames.
None of it is good for your engine and, unless you have Inconel valves in your head/s, it will lead to burnt valves.
Good luck.
How about NO
