Ignition coils
2891 Vistas
How can you determine wether a coil should be set to rising or falling edge.
In almost all instances the ignition system will use a falling edge trigger. The only exceptions I've come across are some Honda, Ford and MSD ignition systems. MSD make it easy as their systems are documented in the instructions.
