ignition drives
2272 Vistas
How to determine how many ignition drives you need for a 4 through 12 cylinder engine, is it one drive per cylinder ?
How many coils will use use? You will need one ignition driver per coil (and a way to configure the ECU for the way the coils are connected (COP, Distributor, Wasted Spark, etc).
