Implications of MAF measurement vs MAF calculation via the speed density principle
8876 Vistas
What are the pros and cons of these two methods? Surely there is an appeal for OEMs to use the MAF sensor to directly measure the Mass air Flow, so why do standalone ECU setups commonly use the speed density principle to calculate the Mass air flow? Does the speed density principle require a sensor/meter of some kind to determine the density of the air, or is some generic density at standard conditions used to calculate the MAF?
Hey Connor,
So from my understanding, MAF is appealing because of its inherent flexibility. The ECU is constantly working to deliver the optimal AFR based on real time readings from the MAF sensor. This means in turn, that it can automatically adjust and compensate for non-standard conditions such as air temperature, sea level vs altitude, etc.
Speed Density (MAP) does use a sensor, it measures air pressure (as opposed to air flow) and engine speed to compute fuel delivery. The ECU (via the sensor readings) utilizes the VE table that we (tuners) program within it to determine how much air will be coming into the engine at a given speed. Based on that, the correct (hopefully) amount of fuel is added to the cylinder.
It sounds like MAP is more difficult, and in a sense it is definitely more tedious, but it has traditionally been much easier to tune than a MAF. MAF's have typically been used by OE manufacturers because it offers a more constant and safer AFR based on their OE standards. This however, is not always what a tuner wants, they want performance. A speed density set up allows the tuner to dial in the exact AFR that they'd like to see based on the air pressure and RPM's which can dramatically enhance or even reduce power.
MAF set ups have also been known to not work very well under high strain (7000k+ RPM) so for a tuner that is tuning a car for drag racing or anything that would require high load's a MAP system is more reliable.
With all of that being said, apparently modern MAF systems are starting to improve dramatically. Many OE cars today utilize both to get the absolute most accurate and safe AFR's for their vehicles.
I hope this helped, and if I am incorrect or misspoke about anything, I apologize.
