K24 AEM Infinity Noisy Cam/Crank Duration Signal
1416 Vistas
Hello, I have a K24A1 with an Infinity 508. I am getting a noisy cam 0 and crank duration signal. It appears to be pulling low. Is this a problem? What could be causing this? Should I be concerned?
The car is running on a modified B Series map. It starts, idles, and free revs fine. I have not taken it to the dyno. I have not driven it. I have not even got it up to operating temperature.
I've linked the log and session where I encountered the issue and included a graph that shows what I'm talking about.
Thanks in advance.
Got a reply from Jeff Evans. "As long as you are not getting misfiring and start sync/start probability are 100% I would not worry about it."
