LM2 INNOVATE DIGTAL WIDEBAND METER to link g4x external wideband
1732 Vistas
Hi team
Im basically trying to work out if there a way to connect my LM2 innovate digtal wideband meter to my link g4x ecu! I do have all the connection available to the kit Ive purchased! I believe i may have to use the analog out to serial to laptop but if this is the case (if im not mistaken) how to I make the link g4x ecu detect my wideband meter to read out to my ecu afr readings instead of matching my readings through my lm2 innovate meter where I can use the ecu to read it instead! As I don't have wideband controller and can bus controller to link plug in!
If this makes sense !
Innovates tend to have poor ground offset issues, though the LM2 has tried to mitigate that by adding discrete grounds for each analogue Out. You'll want to rig the yellow (analogue 1 -) wire to your link's sensor ground, and the light green wire (analogue 1 +) to whichever An Volt in you've got available.
You'll need to configure Lambda 1 to point to the proper An Volt and scale it per Innovates scaling after that.
makes sense why my afr readings were all over the place and i i was thinking it could of being a earthing issue! i was watching a webnair that ANDRE had posted up while back how he used the innovate lm2 digtal meter like i have and used analog to serial to the laptop but it was used in conjuction with VCM system! which worked for him but the system might be different! hence as you stated running yellow wire to ground and light green to positive! at this point im better of going Can Lambda system!
thank you for your support!
