No spark or RPM signal on Crank K11 Micra + Haltech Elite 1500
2346 Vistas
Hey everyone,
setting up my haltech 1500 for my k11 micra and having an issue where im getting no spark or rpm reading when cranking. I have triple checked the wiring and I have the Cam position sensor signal to the Crack Trigger + pin on the ecu and the ignition to the IGN 1 pin on the ecu. I have also checked and the ignition coil and cps is getting 12v and all grounds are connected. Anyone have some advice for things to try
