Opening the throttle with constant RPM
2449 Vistas
Hello,
I am wondering how you can open the throttle without increasing the RPM?
Course: EFI Tuning Fundamentals
Video: Correcting your AFR
Time: 8:38
Thanks in advance for your answer!
BR Anton
Hello it is done by using the dyno in steady-state which means setting the dyno to a controlled rpm lets say 3000 rpm then increasing the throttle position
to increase the load on the engine
Thanks for the answer! So you can not do that on the street?
