Range between MBT and Knock limit
3131 Vistas
Hello
I would like to know how the ignition timing range between MBT and knock limit, I think it will also affected by cylinder diameter, compression ratio, N/A or forced induction.
In the case of N/A small bore engine(about 80mm, motorcycle engine), what is the range between them?
thanks a lot .
It's going to be a case by case basis. You basically have to test it for yourself.
OK, Thanks
