richer air fuel ratio
Módulo correspondiente: Principios fundamentales del motor > Principios del motor > Principios del motor
2118 Vistas
Good day, Im learning from Indonesia, and my english in getting this course maybe limited. when you said in minute 1, about rotary engine likes to run with a richer air fuel ratio, is richer mean use more of fuel?
Yes, richer means more fuel, so the AFR is a smaller number (such as 12.5 : 1 AFR). If you are working in terms of Lambda, it will also be a smaller number (such as 0.85 Lambda).
Because of their design, rotaries also run very hot exhaust temperatures, a slightly rich mixture may also help reliability there, too.
