Rod length.
2328 Vistas
What are the pros and cons of longer VS shorter connecting rod and is the difference worth worrying about? (Same stroke and deck height)
There is a webinar course on here you can view that deals specifically with the technical design decisions on Rod length, i watched it a few days back.
You have to scroll down until you find it or you can search using the below description
153 | Rod to Stroke Ratio Explained
