Rotary Engine Capacity
3319 Vistas
Can we use these VE principles on rotary engines? or does it differ?
Volumetric Efficiency is merely the amount of air the engine is capable of consuming per rpm compared to its actual size. It doesn't matter what type of spark ignition or compression ignition engine we discuss they all work on the same VE principles.
