Should I Use This Base Map?
1245 Vistas
This Base Map came from the Aftermarket ECU made specifically for my motorcycle and its engine, should i let it be (omw to the local dyno) or change the Base Map values?
[ image_2026-05-09_204943791] is the Ignition Timing
ECU: Juken 5 Racing Turbo Basic (no Wideband O2 sensor needed)
Bike: Suzuki GSX-R150 (R125 in some other countries)
each lines represent TPS%:
0%
25%
50%
75%
100%
