Syvecs S6 ECU Base ignition timing setup
392 Vistas
Hi, I made the course for Syvecs S8 with Base ignition timing setup, but since mine is S6, where in the software I could lock the timing?
https://www.hpacademy.com/dashboard/courses/practical-standalone-tuning/syvecs-s8-step-4-base-ignition-timingfuel-pressure
I don't have Reference timing Mode to lock it.
Hi Garrett,
I'm a newbie here, but I noticed something from your screenshot that might explain why you can't find that feature.
It looks like the issue comes down to the Firmware Version (SwVer) your S6 ECU is currently running. If you look at the top bar of your SCal window, your ECU is running an older firmware (v1.42.X).
In the newer firmware versions (like v1.103.X), the Reference Ignition Timing Mode is fully available under the Output Testing folder, just like on the S8.
I highly recommend checking the official Syvecs website to see if you can download and update your S6 ECU to the latest firmware version. Once updated, that menu should appear for you.
Hope this helps!
Thanks a lot. I update the firmware and the options to set base ignition timing is now available
