Trigger Sensor
Módulo correspondiente: Componentes EFI > Entradas de activación
795 Vistas
I have a bit of an odd question. At time 1:02 of the Trigger Inputs video, a sensor is shown. I happen to be looking for this particular sensor as the ones I've found have a connector on it rather than a pigtail. I need and prefer a pigtail like the one in your video. Could you please provide the manufacturer and part number for that sensor?
Hey Emilio,
The one shown in the course is a Honeywell GT101, they are discontinued at this stage but if you use that part number for a search, you'll find plenty of alternatives offered. For example,
https://msel.co.nz/hall-effect-flange-mount-geartooth-speed-sensor/
https://www.efihardware.com/products/2655/Hall-Effect-Crankshaft-Sensor-High-RPM-Version
