Why is desired AFR 12.5
2742 Vistas
Why is desired AFR 12.5 instead of Stoichiometric AFR? and how did you get the number? Thanks
hello the principle of afr is to use a safe afr for the engine too lean it will melt to rich it will bore wash use excessive fuel and generally be down in power the following table shows a general afr table for most street engines with an rpm over map the same map will apply to non-turbo engines if you note the map reading as 100kpa (approx) at atmospheric condition or engine not running
Great, thank you!
