AVCS code on my Newly built EJ25 engine
Ajuste del control de levas variable
771 Vistas
Hi Car enthusiasts,
Am writing from the Sultanate of Oman,
and hoping to get some feedback.
I recently completed a newly built Engnie
From IAG 950 with IAG 750 Cylinder head
the engine assembled locally in Oman.
all sensors are brand new - Tomei High performance oil pump.
as Per IAG new engine break in manual
One of the break in oil that can be used is Amsoil SAE30 , unfortunately it’s very light and with the High temperature in Oman it even thins out more.
after completing 273KM ( 3rd service )
once the car was started everything was ok, as soon as hot ideal the Intake bank2 code popped up..
now am not sure Ist due to the oil used ? ( but way after 273km?)
or the avcs solenoid has failed or jammed?
note : the tuner tried to change the settings as much as possible however it holds then overlaps ..
He suggest to change the Oil used , whoever the other recommended oil by IAG is motul 10w-40 break in oil which is not available in the GCC.
I was hoping to get some information help me overcome this issue and continue engine break in and go for the final tune.
