Volumetric efficiency calculation
Ajuste del control de levas variable
Módulo correspondiente: Principios fundamentales del motor > Principios del motor > Eficiencia volumétrica
876 Vistas
hello....
In a lesson on volumetric efficiency, at the end of the equation, when dividing the actual air flow by the theoretical air flow, where does the number 572 come from? Is it a constant or a variable number? Please explain. Thank you.
