Volumetric efficiency calculation
Variable Cam Control Tuning
Relevant Module: Fundamental Engine Principles > Engine Principles > Volumetric Efficiency
hello....
In a lesson on volumetric efficiency, at the end of the equation, when dividing the actual air flow by the theoretical air flow, where does the number 572 come from? Is it a constant or a variable number? Please explain. Thank you.
