Question about this lesson in the Test Your Knowledge quiz
Ajuste y optimización de la suspensión
Módulo relevante: Conceptos básicos de transferencia de carga lateral > Transferencia de carga elástica de masa suspendida
2646 Vistas
Hi HPA,
I noticed that the question referring to this lesson on the quiz at the end of the module has no correct answer. The question asks about the elements that contribute to elastic lateral load transfer and the answer based on the clip at 0:16 in the video would be the "bump stops, the springs, and the ARBs." There is no answer choice on the quiz that contains these three items. Moreover, there is no answer choice that DOESN'T contain an element of geometric load transfer. The current correct answer on the quiz at the end of the module states that the elements contributing to elastic load transfer are the bump stops, springs, and suspension arms. Please clarify. My understanding based on your teaching is that the suspension arms are part of geometric load transfer. If compliance in the suspension arm or something contributes to elastic transfer then this probably needs to be clarified, but I doubt that this is what you're trying to convey as your lesson attempts to keep things simple.
