MoTeC CDL3 Display Configuration
Análisis de datos de deportes de motor profesionales
Discusión y preguntas relacionadas con el curso Análisis de datos de deportes de motor profesionales
2358 Vistas
Hi,
Configuring a CDL3 Motec dash. Is there a way to limit the channel reading number so you can have more letters?
For example, if I want to display on the bottom line fuel usage in litres, I only need 3 numbers (max 99.9), but it allows up to 9999.9 and limits how many letters I can display. It is currently set as (FUELUSE_9999.9), but I would prefer (FUEL_USED_99.9)
Is this possible? I couldn't work it out if so.
Cheers,
Ryan
No, ADL, SDL and CDL displays can only display either 7 alpha + 6 value digits (one value), or two 2 alpha + 4 value digits, or three 3-digit values (no alphas).
That was a big advantage of the color displays.
I find leaving out vowels usually works, so FUELUSD is more understood than FUELUSE
Thanks David. Definitely puts the C127 further up the wish list.. maybe one day.
