Debate y preguntas relacionadas con el curso Análisis de datos en el automovilismo profesional
Hello people,I am trying to align a few incidents on the track which I have noted down from a race where I was physically present and also have telecast and race clock information of. and I am trying to find the answers on what might have caused certain incidents with the help of the data and for this I want to align the time stamp of the log file with real time or race clock.the only channels relating to time I could find from the files are GPS time and GPS unix time but I could not make use of it, I tried to decode it and try to check with actual clock but it does not make sense.
I also wanted to know when does the car starts to log it's parameters, which will also help me to connect the information with a clock(it is easier when you know the time when the car actually started logging), I even tried to look under Logging option inside Motec M1 tune's file of the same car but could not find any relevant information, may be it is configured in the dash logger, right?
I am using Motec i2 free version.
Thank you gentle men for looking in to this.
There is actually no GPS data for any GPS channel in this log file. The channels are logged but they contain no values which could suggest the GPS was faulty or not connected. I'd ensure you're actually seeing valid GPS data in the M800 as a next course of action. I can't view the device configuration so I can't see what your logging start/stop parameters are. you will need to confirm this inside the M800 under Adjust - Data Logging Setup - Start/Stop Parameters.
Once you have actual GPS time in the log file then you can convert this to your local time zone since the GPS time channel is UTC. MoTeC GPS time is recorded as HH:MM:SS.sss. For example, 213415.250 means 21:34:15.250 UTC.
Hello friend sorry I think I have attached the wrong file (see file size)
Could not upload the file directly here due to errors
so throwing a google drive link for the file in question. [url=https://drive.google.com/file/d/1fPeVaRThhvuBaxp1zQRtRxl7y9AkYKKs/view?usp=sharing]https://drive.google.com/file/d/1fPeVaRThhvuBaxp1zQRtRxl7y9AkYKKs/view?usp=sharing
I can't access this file so I have requested access. Thanks
Am I correct to assume your location is in the Netherlands? What was the approximate local time of this log file?
