Cam card
Cómo graduar una cámara
Debate y preguntas relacionadas con el curso Cómo obtener un título en Cam
1540 Vistas
Just needing confirmation as where to measure valve open points not sure if it’s pushrod or valve retainer
tia
With that card, it should be at the follower/lifter. If the pushrod is aligned correctly, in line with the follower, it can be much easier to use it as an extension.
It's a hydraulic cam' and you may find it much easier to do it correctly by using a couple of mechanical followers, to double check on both in'and ex', or machine a couple of blanks.
