Crankshaft gear timing spocket 1994 honda b16a3 obd1
Cómo graduar una leva
Módulo correspondiente: Habilidades prácticas > Encontrar el verdadero TDC
1057 Vistas
i have a 1994 Honda b16a3 odd1.my crankshaft timing gear spocket has the built in woodruff key Is it normal for the crankshaft timing gear spocket to have a bit of slop from left to right as in retarded and advanced ? i have no up and down play only left and right play that is causing my timing and degree readings to bounce around.is that normal for obd1 honda b16a3?
