Dial indicator question
Cómo graduar una leva
Módulo relevante: Habilidades prácticas > Cómo ajustar y utilizar un reloj comparador
1267 Vistas
What is the dial indicator tip pressed/fitted against for the reading. Is it the top of the valve needle where the retainer sits? I wish you included the view in your video.
