Opening and closing events different
Cómo graduar una leva
1396 Vistas
Following instructions from the course on a DOHC (2JZ).
I am getting an IVO event 23 degree's retarded and then a IVC event 9 degree's advanced.
Can this be anything other than my homemade tool for getting a dial pointer on the bucket being shit?
How are you guys getting a decent reading while getting around the cam and onto the bucket?
That is pretty much what i use but I lean the rod to make sure it goes up and down in line with the bucket so it doesnt move sideways
i mount the base on a home made plate attached to the rocker cover bolt holes
I since revised it like this, and I got the same results x3. But the opening and closing still don't match?
I've abandoned this method and finding the information is maddening. I think I know what I can do, I managed to measure peak lift of 9.6mm @ 117 degree's on the intake using the centre line method. Spec is 9.6mm @ 110 degree's. I think I am right in thinking that I can just set the cam to this.
It isn't to the courses specifications but then I can't get the information I need whilst the centre line method is more generally covered in the US and as a result; the information is more readily available on the net.
