Un lugar para comprar, vender e intercambiar equipos y suministros para el curso HPA. Se aceptan widgets de ajuste, aparatos de cableado, artilugios para la construcción de motores, herramientas de fabricación, accesorios de alineación y mucho más.
Has HP academy discussed IMAP/EMAP (intake pressure/ exhaust pressure) in a past webinar or article? If there's any info on this, could someone point me to it?
Here are some things I found by using the forum search for "MAP/EMAP"
https://www.hpacademy.com/forum/efi-tuning/show/air-density-6
https://www.hpacademy.com/forum/webinar-questions/show/136-how-altitude-affects-your-tune
And the webinar on Altitude effects:
https://www.hpacademy.com/previous-webinars/how-altitude-affects-your-tune/
Hello,
I am looking for confirmation of my thinking. When Tuning IMAP/EMAP, What is the Boost area, Boost Threshold and vacuum region values. I would assume an IMAP/EMAP value of 1.0 to be the boost threshold, a value less than 1.0 to be the vacuum region and a Value Greater than 1.0 to be the positive boost region. Is this Correct?
Thanks, Javier
No, it becomes pretty difficult to differentiate in many conditions. Over-run/cruise will always be significantly less than 1.0, small road car turbos will usually result in >1.0 on boost, but with a decent hot side you can be less than 1.0 the whole time - even at full boost WOT.
