TFX Engine Technology - Engine Pressure Analyzer
Compra, venta e intercambio
Un lugar para comprar, vender e intercambiar equipos y suministros para el curso HPA. Se aceptan widgets de ajuste, aparatos de cableado, artilugios para la construcción de motores, herramientas de fabricación, accesorios de alineación y mucho más.
3792 Vistas
Hello Everyone. I'm Selling a TFX Analyzer unit in perfect condition never used.
It's a super high speed 8-channel logger that logs data from a pressure sensor located in a specially modified spark plug to give you realtime and logged combustion pressure data. For seeing exactly what's actually going on inside your chamber, to allow you to optimize A/F ratio and timing curves to a far greater degree of accuracy than any other tuning method. You can find all the info at the tfx website.
TFX Engine Technology - Engine Pressure Analyzers
I have the 8 channel logger, with one of their high pressure combustion pressure sensors, as well as hardware and software options to use any factory crank sensor signal in place of the high speed add-on crank sensor.
I paid 6,690€
I want 4,500€ for it. TFX will support and warranty it, but they will require the new owner to pay a one-time licensing and tech support fee of 850€, so you could own this 6,690€ setup, never used, for 5,350€
The logger I have is intended to be used as a dyno based system, but can be used in-car as well. I only have one instrumented spark plug for it (16mm socket 8 heat range Spark plug), because they are 1,395€ each but the logger will support up to 8 of them for individual cylinder tuning all at the same time.
I can ship it Worldwide, I'm based in FRANCE, the prices are Without VAT of course.
Thanks
Christos.
Not that I am after it, but I would specify the currency that you are pricing it at.
Good question, I would normally assume US$, that's what most of the world thinks of when $ is used, but as it's a Canadian product, there could be some confusion if they're all US$ or a mix with CAN$ pricing?
The whole package is much cheaper than I would have expected, and looking at the range of transducers (sensors) available, it would make a very good tuning tool for the serious enthusiast/tuner.
On that, what sparkplug design and heat range is the one being sold with it? If a buyer needs a different one it will affect how they value what appears to be a bargain.
Well, HPA is a NZ based company so it could be in NZD. Someone in Fiji could get a really good deal.
Hey guys, Currency Changed, I deal only with €€ …
Thanks.
Did you end up selling this ?
