CAN Bridge / Power Supply
Comunicaciones CANBus decodificadas
Módulo relevante: Ejemplos resueltos > Configuración de red: vincular la ECU a AiM Dash > Paso 4: Programar los dispositivos para transmitir los datos requeridos
1521 Vistas
What components are you using to make your CAN Bridge? Also what Model power supply are you using for bench testing ?
i made my own utilizing a stm32g4 mcu and some supporting hardware.
been working on the framework for the past month or so, will be revealing it at PRI for people to see.
3 CAN buses , software definable termination resistors, all programmed in C (but with very easy to use framework to avoid adding complications for newcomers to the programming world)
Mitch, what is your company name / booth # at PRI? I will try to stop by to check it out.
I'm just walking around. I'll be in a Hpacademy hooded sweatshirt all.3 days to make it easy to find me :)
