HEX tpo decimal conversion
Descifrando las comunicaciones del bus CAN.
Módulo correspondiente: Antecedentes técnicos requeridos Teoría > Big Endian y Little Endian
Debate y preguntas relacionadas con el curso "Comunicaciones CAN Bus Decodificadas"
2006 Vistas
In this module you describe the conversion of HEX 8A02,converted to decimal as 33,794. I have checked this on the Windows calculator and it is incorrect. This decimal number converts to HEX 8402. HEX 8A02 converts to DEC 35,330. Maybe it was a typing error since the 4 and the A look similar at a glance.
Kia ora Raymondo,
Thank you so much for letting us know - great find to be honest.
Yes, you are correct: it should be 35,330. I will work that into the captions ASAP. Unfortunately, changing what is said will not be that easy haha.
Thanks again, and aku mihi (best regards),
Marcin from HPA
