MoTeC CAN Channel :: DBC Factor/Offset Spreadsheet.
Comunicaciones CANBus decodificadas
2673 Vistas
Sometime's it's a struggle to Scale in a MoTeC CAN Channel when you're comparing it to a DBC File. And while they do have a DBC Import function, it's not a 100% guaranteed result and sometimes it will throw errors.
Here's an Excel Spreadsheet I use when I'm comparing what MoTeC uses vs what the DBC file says.
  • Motec-CAN-Channel-Calculation.xlsx
Thank you for sharing
