autosport connector help
Cableado práctico para deportes de motor - Nivel profesional
2821 Vistas
Hey
Afte ordering twice the wrong connector, I hope someone can help selecting the correct one.
I need connector for
20awg wires
And 30 -40 wires.
So to figure this out, you start with the Autosport Catalog found here:
https://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=1-1773721-8_as_interconnection&DocType=DS&DocLang=EN
Then you look for a contact arrangement that has the necessary number of #20 terminals. I would suggest 18-32 (32 #20 terminals), 20-39 (37 #20 and 2 #16 terminals), or 20-41 (41 #20 terminals).
Then you decide which side wants to have Pins, and which Sockets. Then choose the right flange / receptacle.
So for example, you might want AS620-39SN for the Plug and AS020-39PN for the Receptacle.
If you don't care about Autosport, you might want to use Milspec connectors such as MS3470A18-32S (33 #20 Socket terminals), with the mating MS3476A13-32P Plug.
That the problem my orders were from this catalog 😁 and order wrong connector twice.
I will try the one you mentioned
Thanks
You don't provide enough info to help. What did you order -- and why?
I order the one without the 20 awg wire just 22-26
Now I split the harness for 2 with 2 auto sport connector. And ordered MS3470A18-32S (33 #20 Socket terminals), with the mating MS3476A13-32P Plug.FOr the 20 awg wires .
Thank you for the help
Make sure both sides are 18-32, I see I made a typo myself were I said 13-32 (should be 18-32) on the MS3476
