Combination air sensors. Bosch
Cableado práctico para deportes de motor - Nivel profesional
2488 Vistas
https://www.ellis-components.co.uk/bosch-motorsport/sensors/p/pressure-sensor-combined-pst-f-1/in/derry
Hey these Bosch T-MAP fluid (PN 0261230340) sensors are awesome for fluid. Does anyone have info on a pressure and temp sensor that can be put in the air system is IAT IAP MAP. Basically the complete Intake and charge pipes I would like to be able to run just 1 sensor type the whole way through. It would also have to be able to run vacuum.
Also I’m after a high temp sensor that will be able to withstand the temps of the charge air right out of the turbo. Maybe 200deg C without having to run a EGT. I see Honeywell do one you to 140C
Sorry, this forum is stupid how it messes up links, Im sure you can work it out...
Haha thanks mate I will look at them now
Hey so those Bosch sensors. These will be the adaptor for them?
https://www.efisolutions.com.au/bosch-map-tmap-sensor-weld-on-flange
