Which crimp tool for Deutsch high current connector ASHD614-1SN-C25
Cableado práctico para deportes de motor - Nivel profesional
3684 Vistas
Hi Guys,
I have most of the tooling for all the size connector pins I have, EXCEPT the one for crimping the ASHD614-1SN-C25.
For the pin I need it for it has a 125A cont. current rating, so it will be a 25mm² wire (I suppose).
The site of TE doesn't offer the needed tooling option for this connector...
I did find the crimper for the size 4 contacts, but it's mentioned that it's for the DTHD connector contacts size 4/8 :
https://deutschconnectorstore.com/product/18870-deutsch-heavy-duty-crimp-tool-size-48-contacts/
Would this also work for the size 4 contacts of the ASDH series ?
"Funny" side note: on the datasheet of the ASDH size 4 contacts the current rating is 100A (on the Cosworth IPS32 it's specified it can handle 125A)
Hello David.
The tool that you provided with link accepts only 6, 8 and 10 Awg wire. For 4 Awg wire I can suggest you to use this tool:
https://www.waytekwire.com/item/497/Molex-19284-0034-Hand-Crimping-Tool-8-4-0-AWG-/
I personally used it for ASHD contacts and it crimps fine. Also it is a lot cheeper and manufactured by Molex.
As for current rating: TE data sheet states that it can accept 125A continuous current, 150A for up to 4 hours and up to 3 minutes at 200A (dependant upon ambient temperature)
My experience is that any hex crimp tool with the right size die will do a good job, but it will have to be a hex-crimper, not an indent crimper, to allow the terminal to fit into the connector body once it has been crimped.
Not that I would recommend it in any way.... But I have used my cheap ali-express hydraulic hex crimper for these terminals, and with a bit of fiddling it worked fine and had a good crimp.
Thanks Zac,
Found my answer here after a quick search through the forum.
